Example Code
Synchronized Analog Output on Multiple Devices (RTSI/PFI) Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI shows how to create two Analog Output tasks on two separate devices and use one hardware clock to control both devices.
Description
In this case, we set the rate for Device 0, then export the clock to a RTSI line, but you can also use a PFI line. You can externally connect the RTSI bus or the PFI lines, so the two devices can share a clock.
Note that the slave task must start before the master.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Configure the physical channels for the two analog output tasks.
  2. Specify the analog output rate and the data you want to output.
  3. Run the VI.
VI Snippet
