Overview
This VI outputs a waveform on an analog output channel and bring the signal back into an analog input channel.
Description
Please note that this requires a physical wire connection between the AO and AI channels, and the user must specify the correct device in the VI. Also, you must specify the sample clock source of the analog input to be the AO sample clock form the same device, along with having the same rate and number of samples per channel.
Requirements
Software
Hardware
VI Snippet
Thanks David. I have updated accordingly.
