Description
Description-Separate-1This example shows how to acquire filtered frequency measurements with the NI 9326 and synchronize those measurements with analog measurements from another module in the same chassis.
Description-Separate-2How to Use
How-Separate-1First select the 9326 module and counter you wish to use for your frequency measurements. Next select the analog input module you want to synchronize with. Configure the front panel for your measurement by setting timing and filtering settings. If you need more information about the 9326 configurable filters, please reference the NI 9326 Datasheet located in the related links section.
How-Separate-2Additional Information
Additional-Separate-1The NI 9326 was designed with a few specific sensors in mind. The sensor types include variable reluctance sensors, encoders, and hall-effect sensors. It was also designed as a replacement for the SCXI-1126 hardware. If you have used the 1126 in the past the 9326 may be a suitable replacement for that hardware with improved performance and up to date software support.
Additional-Separate-2Related Links
Related-Separate-1NI 9326 Datasheet
NI 9326 Getting Started Guide
NI DAQmx Download
Obsolescence Planning
Related-Separate-2
