Example Code
Synchronize Directories in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI demonstrates how to synchronize two folders in LabVIEW.
Description
In LabVIEW you are able to perform multiple operations on system folders, like checking the size and presence of files inside of a directory. In this example, after you click Search, a subVI checks for files that exist in the Master folder that are missing in the Slave folder and compares file sizes of existing files with matching names. It finally returns a list of all files that need to be synchronized and allow you to choose which ones you want to synchronize on the front panel of the top level VI. After you choose the appropriate files and click Synchronize, another subVI uses the Copy function from the Advanced File Functions palette to copy files from the Master folder to the Slave folder.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached compressed folder to your computer
  2. Open the VI "Synchronize Directories LV2012 NI Verified.vi"
  3. Run the program
  4. Select the path to the folders and which one to synchronize
  5. Press Search and select the files to synchronize, then press Synchronize
  6. Click on the STOP button
VI Block Diagram
Sync Directories LV2012 NI Verified.pngSync Directories LV2012 NI Verified.png
greetings from the Netherlands
Comments
BetaCommunityCo
Member
Member
on
thanks for the feedback Albert
A couple of my weaknesses are neatness and documentation. I am working to correct those bad habits but sometimes time contraints make it tough.
