Example Code
Synchronize Analog Input on Multiple USB Devices Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example shows you how to synchronize AI for multiple USB devices.
Description
This example shows you how to synchronize AI for multiple USB devices. You need to create an analog input voltage channel for both the Master and Slave devices. Then set timing parameters.  Note that sample mode set to Continuous Samples.  In this example, the Rate must be the same for both devices since we are sharing the sample clock.
Requirements
Software:
  1. LabVIEW 2012 (or compatible)
  2. NI-DAQmx
  1. Specify your USB devices that you want to synchronize.
  2. Run the application.
VI Snippet
With warm regards,
David D.
Comments
kusg
Member
Member
on
Thanks for the tutorial on how to setup multi-device usb synchronization. It would be great if the example code is also available in DAQmx ANSI C.
vinayakakhil
Member
Member
on
I have an issue regarding synchronizing  two USB 6210 data acquisition cards. From one DAQ I am acquiring 3 phase voltage data using  3 analog (ai0,ai1,ai2) channels and another 6210 used to acquire 3 phase current data  (ai0,ai1,ai2). Sample rate of each channel is 80k . So my aim is to synchronize the ai0 of usb1 and ai0 usb2 so that the data acquisition is happening simultaneously . This is applicable for ai1 and ai2 of two usb devices. I have seen your model and try to run the model. it is showing the massage
Error -89136 occurred at DAQmx Start Task.vi:7220002
Possible reason(s):
Specified route cannot be satisfied, because the hardware does not support it.
Property: SampClk.OutputTerm
Destination Device: Dev1
Destination Terminal: PFI0
Task Name: _unnamedTask<CA10>
Kindly help me sort out this issue
Juld23
Member
Member
on
I am a beginner in LabVIEW programming,
I am in project of end  study, I am mounting a test bench for the measurement of temperature (thermocouple type K), voltage and position. this acquisition must continue. The position I will use the displacement sensor of Keyence LK-G3000 series (Laser sensor).
To begin I tried to make a small Vi of temperature but I am confronted by several problem.
Can someone direct me on how I will proceed to enlighten me the way. That is to say how I can take me.
