Para descargar el software de NI, incluyendo los productos que se muestran a continuación, visite ni.com/downloads.
Overview
Demonstrates how to use a GPS PPS signal in hardware to trigger and control the execution timing of a software loop.
Description
Unlike DAQmx Events on M and X Series devices, niSync hardware cannot directly generate a software event. However, if you want to sync your software execution timing with GPS (or any external trigger), you can create a physical clock on the 6682 (GPS PPS) that is used to trigger timestamps. By using a blocking read on the timestamp data to control execution flow, you can ensure that your software loop only fires when a timestamp is latched. This causes the software only to iterate when a physical trigger is received.
Requirements
Software:
2a. Configure timestamp trigger.
2b. Configure GPS PPS for 1 Hz.
3a. Blocking timestamp read triggers loop execution to continue.
3b. This code is not required, but it shows the current GPS timestamp. It simply keeps the PPS output signal from disabling until Loop 1 completes.
6a. Disable timestamp trigger.
6b. Clear PPS clock configuration.
VI Snippet
El código de ejemplo del Intercambio de Código en la Comunidad de NI está autorizado con la licencia MIT.
Please, save for Labview 2011.
2011 version of main VI posted.
