Example Code
Subpanels with Communication Between VIs Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates the ability to run one VI inside of another VI with a subpanel and have these VIs send and receive data to each other.
Description
The Main VI contains a subpanel inside of which the Auxiliary VI is displayed and started. The Main VI sends a user-controlled waveform type to the Auxiliary VI which is the displayed in the subpanel. Additionally, the Auxiliary VI sends user-incremented or decremented tank level values to the Main VI which contains a front panel level indicator.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Be sure the project and its dependent VIs are all in the same directory.
  2. Be sure the Auxiliary VI is closed (if it's open, the subpanel with not display it).
  3. Run the Main VI.
  4. Change the Waveform Type or Increment/Decrement the tank values and observe the changes.
Front Panel of Main.vi
Block Diagram of Main.vi
**This document has been updated to meet the current required format for the NI Code Exchange. **
Rick C.
