Example Code
String to Boolean Array of LEDs
Code and Documents
Overview
The example demonstrates how you can manipulate arrays by moving the first column of a 2D array, to the end.
Description
The user inputs a string which is then converted into a 2D array of boolean values. This is then shown as a moving message on the front panel. To achieve this, the array is manipulated by moving the first column to the end every iteration until the code is stopped.
  1. Run the Main VI in the project
  2. Press OK on the dialog box that appears
  3. Enter string into string control and press done
Requirements
Software
LabVIEW 2013
LabVIEW 2014
Additional Images or Video
Jinfone
Contributors
