Example Code
String indicator "text to size" property workaround
The indicators for strings do not allow you to use the "text to size" property.  This example shows you how to change the length of the string indicator to show all of the characters. To workaround this you can set the string size width to be proportional to the number of characters in the string.  See below.
This doesn't work perfectly for smaller strings.  A better method for scaling could be implemented.
Justin Parker
Product Support Engineer
Contributors
