Example Code
String Text Format by Tag
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to format a string using HTML tag.
Description
Using this example, you can properly format a string value by using HTML tags. This could be useful, for example, to display text in dialog box.
The HTML tags that are recognized by this example are the following:
<b> Bold </b>
<i> Italic </i>
<u> Underline </u>
<s> Strikeout </s>
Requirements
  • LabVIEW 2012 (or compatible)
  1. Unzip the attached zip file
  2. Open Format Text by Tag - Caller LV 2012 NI Verified.vi
  3. Modifiy HTML String control as needed
  4. Run the VI
Caller VI Block Diagram
String Text Format by Tag - Caller LV 2012 NI Verified.pngString Text Format by Tag - Caller LV 2012 NI Verified.png
