Description
Description-Separate-1
For one side, it takes the written table, converts it to U8, and then sends it over (U16) Modbus TCP. Finally, on the other side, a table is obtained from U16 and then converted to a String table.
As a result, the same table that was written is obtained.
Description-Separate-2
How to Use
How-Separate-1
To run this example, you must have NI Modbus installed.
How-Separate-2
