Overview
Coding that exemplifies how to insert user defined data into a 2D array.
Description
This Example code shows how to allow the user to choose a number of items (in this case Parts) to input values for. It then stores those values into an array and stores each part's array into another array that can be viewed.
Requirements
LabVIEW 2012 (or compatible)
1. Select the amount of rows you would like to add
2. Run the VI
3. Add the values when prompted
