Example Code
Store Different Types of Data into the Same Array Using Variants in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI demonstrates how to store different types of data into the same array using Variants.
Description
In LabVIEW you are not usually able to create arrays containing different data types. Using the Variant data type, you are able to convert any data type to a single format and create an array with a consistent data type.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached files to your computer
  2. Open the VI "Create Generic Data Type Array LV2012 NI Verified.vi"
  3. Run the program
  4. Change the Numeric control and click Add Numeric
  5. Change the String control and click Add String
  6. Change the Boolean control and click Add Boolean
  7. Click STOP to stop the VI
VI Block Diagram
Jared S.
Applications Engineering
