Stop Button Functional Global Variable
Productos y Entorno
Esta sección refleja los productos y el sistema operativo utilizados para crear el ejemplo.
Para descargar el software de NI, incluyendo los productos que se muestran a continuación, visite ni.com/downloads.
    Software
  • LabVIEW
    Lenguaje de Programación
  • LabVIEW G
Código y Documentos
Adjunto
Descargar todos
Description
Overview
This VI shows how to use a Functional Global Variable to stop multiple parallel loops.
Description
Within a loop connect the loop's stop condition to stop in and the loop's error cluster to error in, reset remains unconnected (default: FALSE). When stop in is true or an error is present, the value is stored and then read by all instances to stop all loops.
To reset the FGV connect a reset constant to reset. In the reset case the status from error in is stored. If the FGV is reset while an error is present, stop out is TRUE, otherwise FALSE.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached file to your computer.
  2. Open the VI "Global Stop FGV.vi"
  3. Add to a VI containing multiple while loops. Run the program.
VI Block Diagram
Miriam
Field Applications Engineer
NI Colombia
CLD
El código de ejemplo del Intercambio de Código en la Comunidad de NI está autorizado con la licencia MIT.
