Example Code
Split a string using a token in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to Split a String using a Token (the default token is the space).
Description
The VI uses the Search/Split String Function that allows to pick the substring before match from the Input String. The For Loop iterates the number of characters of the Input String.
Requirements
LabVIEW 2012 (or compatible)
  1. Type a string into the Input String Control (the default token is the space)
  2. Run VI
Christian A
