Example Code
Sorting Multicolumn Listbox by Clicking on Column Header using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to sort a multicolumn listbox by simply clicking the column header. These are modifications of code written by user LaRisa_S (Her code is located here: MCL Sorting).
Description
This example is designed to allow the user to sort a multicolumn listbox by any of the columns just by clicking the header. The main VI uses the subVI to sort the multicolumn listbox. As seen in the main VI, to use this, the user will drop the MCL Sort By Column.vi on to the block diagram, and use an event structure to fire on the event of the user's mouse coming up while on the listbox. The MCL Sort By Column.vi will receive a reference to the listbox, and will then sort the elements either ascending or descending (based on the last click).
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open the VI "Multicolumn Listbox Sort 2012 NIVerified.vi"
  3. Run the program
VI Front Panel
VI Block Diagram
GCentral ChampionCLA
Comments
Its_Me_Ashiq(ஆஷிக்)
on
Dear all,
This code comes in handy when sorting the MCList Box. I wonder I found it now only.
But I'm not sure how many people are aware of a bug in this module.....
I found the bug when I'm running the attached Multicolumn Listbox Sort 2012 NI Verified.vi.
The bug is in the MCL Sort By Column.vi.MCL Sort By Column.viMCL Sort By Column.vi
The bug is with the value -2.
But how Smiley Surprised ?
Get Clicked Column HeaderGet Clicked Column Header
Wait look at this pic,
MCList Box with visible Row HeadersMCList Box with visible Row Headers
When we click any cells in the MCList Box, that invoke node returns a value of -2 ,and it gives value form 0, 1, 2...(n-1 Columns) when we click on any Column Header.
But when we click the empty and unused column located above the Row headers,
Unused Column In MCList BoxUnused Column In MCList Box
the marked place, invoke node returns a value of -1.
If it happens, the MCL Sort By Column.vi will remove all the items from the MCLBox.
So the value -2 has to be replaced with -1.
Thank you for your kind attention Smiley Happy .
