Example Code
Sort Two-Demensional Array by 1st Column Value
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI sorts a two-column array by its first column, then sub-sorts by second column values.
Description
Another version of Sort 2D Array, very simple. This VI sorts a two-column array by its first column, then sub-sorts by second column values. It shows what Index & Bundle Cluster Array function can be used for.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Set values for the Unsorted Array and Priority Columns (0).
  2. Run the VI
VI Snippet
undefined
Product Support Engineer
Comments
plapsldpla
Member
Member
on
Excellent! just what I was looking for!  You may have to transpose the 2D array if you are having a truncated output.
TimsTools
Member
Member
on
Please consider this alternative.  2D Array Multi-Column Sort Ascending / Descending POLYMORPHIC.
https://decibel.ni.com/content/docs/DOC-48871
It works for all common datatypes and allows the user to select 1 to n columns to sort on.
Tim
