Overview
A simple implementation of a sinc interpolation algorithm.
Description
This VI implements a simple sinc interpolation algorithm, using Shannon's Interpolation Formula:
http://en.wikipedia.org/wiki/Whittaker%E2%80%93Shannon_interpolation_formula
Note: The LabVIEW VI "Resample Waveforms.vi" when using "FIR filter" interpolation also performs sinc interpolation, with better accuracy at the beginning and end of the resampled waveform.
Add Sinc Interpolation.vi to your project
Connect your waveform to interpolate and the new desired sample interval (dt)
Run VI.
Requirements
Software
LabVIEW 2014
Hardware
None.
Additional Images or Video
Dear Nathan, if I just want to use part of the sample to interpolate, say 10 samples from left ang right of the interpolation point, to reduce the computation time, how to modify your codes to do it? Your codes workes well for all the samples point. Thank you!
