Example Code
Simple State Machine - Temperature Control Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to create a simple state machine architecture which shows a simple control of a slider representing temperature of water
Description
This program shows a simple state machine architecture and it's fundamental components; a TypeDef Enum, a loop, and case structure
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the .zip folder
  2. Open the project
  3. Open main.vi
  4. Run the VI
  5. Move slider and observe program response to the stimulus
VI Block Diagram
Daniel G.
Semiconductor & Wireless
Comments
Enrique.Noe
Member Member
Member
on
utilizas variables locales cuando se puede evitar.
Se usa property node con propiedad "value", esto se evita si manejas un cluster con un shift register para enviar todos los datos de un estado a otro.
Saludos!!
