Example Code
Simple State Machine: Concept demonstration in LabVIEW
Code and Documents
Overview: This is simple State machine for the demonstration of state machine in LabVIEW concept
Description: Demonstration of the Concept of state machine
Hardware and Software Requirements: No Hardware required
Steps to Implement or Execute Code: Simple execute button press
Comments
altenbach
Knight of NI Knight of NI
Knight of NI
on
  • If you would place the LED indicator terminals after the case structure, you would not need local variables.
  • If you switch the state before the case when stop is pressed, you don't need the lower shift registers.
  • A +1 will rotate through the states. All you need is a single enum constant.
  • An example program should have the front panel and diagram aligned with the visible window area, not offset and partially hidden.
  • This entire thing could be done with much less code (code in image below does exactly the same thing).
  • Latch action booleans should use buttons, not switches on the front panel.
  • Typically, the color of structures should not be changed.
  • It makes no sense to spin the loop as fast as the computer allows.
  • In my example, the real state code would be in a separate case structure parallel to the second case structure. This way the right LED lights up at the same time when the state code starts executing.
Contributors
