Example Code
Simple Sound Sequencer in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to load up 3 .WAV Sound Files into an 8 beat palette and generate some basic tunes.
Description
This VI uses a Output Sound VIs to create a Sound Sequencer. First Creates a 2D Waveform from 3 .WAV Files. The user Clicks on a Control Array Boolean Related with the three .WAV Files. Every Click will play a Sample of every .WAV File. Using a Producer-Consumer Pattern, the Producer Iterates Row and Columns looking for True, each True of Control Boolean Array Mixes Samples and Enqueue Element. The Consumer uses Output Sound VIs to output sound of combination of the 3 .wav Files.
Requirements
LabVIEW 2012 (or compatible)
  1. Load 3 .WAV short sample files
    (Long samples will get cut short in the next beat (overflow output is there ready to be coded in)
  2. Enter the Sample Rate of your files, ideally they would all be the same although it will work fine otherwise
  3. Run VI
  4. Click on the green LED's of the Array Control to trigger the sound for that beat (You could resize the Boolean arrays to get more beats/lines and change the code accordingly)
