Example Code
Simple Menu Builder Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The attached vi's shall help to create menus easy and simple to react on the selection.
Description
The menu can be defined in an ini file or fixed in an array. An event handler analyse the selection and execute the defined command.
Currently possible commands are:
  • set a cluster element
  • send a queue command
Requirements
Software
LabVIEW 2012 (or compatible)
1. Open the main functions. The main functions can be seen in the Example folder, it's a sub folder of the MenuLib folder.
2. Run the VI
Additional Information or Reference
mage1: Menu data from an ini file
mage2: Menu data from arrays
Ideas for Version 2_0_0:
  • enable/disable the main elements
  • insert new commads
  • allow more than one command for an element
