1. Overview:
This VI performs a countdown before killing the execution of the application set as parameter
2. Description:
Say you are a volume license administrator, and your users keep forgetting to quit LabVIEW when they are done using it. This causes other users to complain that there aren't any licenses available. Since VLM won't register a license as unused until LabVIEW is closed, it might be useful to have some type of application that reminds users to close LabVIEW or checks if they are active at their computer. This is as simple example to demonstrate how someone might get started writing an application along those lines.
This VI prompts a user to renew a license, resets a timer if they choose Renew License or quits LabVIEW if they choose Release.
I chose to use the command line to terminate rather than the Quit LabVIEW VI to make it useful for more applications than LabVIEW. The change is easy if you would prefer to have the application only for LabVIEW and don't want to invoke a command prompt.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
This example is set up by default to terminate notepad.exe, as the source code will be running in LabVIEW. Since this VI can be used to terminate any process, the user can change the process to terminate to labview.exe once they compile to an executable.
VI Front Panel
