Example Code
Simple Get and Put commands using Windows Command Line FTP Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI executes simple Get and Put FTP commands to retrieve a single file from a remote FTP server.
Description
The File Transfer Protocol (FTP) is the standard network protocol used for the transfer of computer files between a client and server on a computer network. This VI creates temporary file ftpcmd.txt. Then it builds the text which is provided into the file that will contain the FTP commands, executes the commands within ftpcmd.txt and finally deletes ftpcmd.txt.
Requirements
LabVIEW 2012 or compatible
      1. Insert Controller IP Address, Remote Path, Remote Filename, and FTP Action
      2. Run the VI
VI Block Diagram
Simple Get and Put commands using Windows Command Line FTP LV2012 NI Verified BD.jpgSimple Get and Put commands using Windows Command Line FTP LV2012 NI Verified BD.jpg
**This document has been updated to meet the current required format for the NI Code Exchange. **
Mark
NI App Software R&D
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting.  Do you mind changing your attachment to include the LabVIEW version?  "_lvXX.vi" would be fine.
Todd S.
LabVIEW Community Manager
LabBEAN
Active Participant
Active Participant
on
Cleaned it up, made required terminals "Required", and got rid of the enum since I always type define enums and didn't want to pass around a CTL with this VI.  Also, for my app, I wanted to pass in the Remote File Path as a single string input.  Gave you credit on the diagram.  I'll email it your way in case you want to post my version along side yours.
Nice work.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
