Example Code
Simple FPGA Hardware Scheduler (Multi-channels)
Code and Documents
Overview
The goal is to provide a FPGA-based Hardware Scheduler that can be used for Tx applications like Arinc-429, Serial, CAN... For instance, there are some cRIO modules with Arinc-429 Tx Line Drivers, CAN Channels, Serial Drivers but they don’t necessarily all come with a hardware-implemented scheduler (in the module or resident in LV-FPGA part).
That type of communication often (not always) requires Elements scheduled to be transmitted periodically. Each Element can have its own period.
This example is a “low-cost” implementation, with multi-channels support of a FPGA-based scheduler. The idea is to keep FPGA usage as low as possible and, also, CPU usage as low as possible. The code can be used on any NI FPGA target. It should also be usable on Windows or Real-Time target for Host side. On FPGA side, it’s a serialized implementation of the Scheduler: all Elements from all Channels are processed by a unique code. Because of serialized implementation, the critical FPGA code has a certain execution time (Cf. Execution Performances Chapter).
Via Host Functions, developer has the possibility to define, per Channel, per Element, the period, default Data and whether it’s Enabled/Suspended at beginning (before starting). Then, while running, user can Resume/Suspend scheduling of each Element and update Data value of each Element.
Host Software Support
Scheduler comes with a basic Host API. Where not initial target, Host SW API should also run under Windows (not tested).
Here is the List of High-Level User functions that are exposed by the Host API. The examples use some of these functions.
Load Scheduler Settings
This function is called before starting Generation.
It covers, per Channel, different settings:
Element settings used, for each:
  • Enabled State (Enabled/Disabled)
  • Element Value (U32)
  • Element Period (ns)
NOTES:
  • It’s not mandatory to pass Channels settings in order, function reorders them anyway.
  • If some Channels are unused in Channels range, that function adds empty Channels (it consumes one Tick per empty Channel). For instance: if settings are passed for Channels 0, 3, 4 of Scheduler, this function adds empty Channels (no Element inside) for Channels 1 and 2.
Start Generation
This function enables the Generation on all Channels.
Stop Generation
This function disables the Generation on all Channels at end of current Scheduler cycle.
Update Elements Enabled State (To be Added)
This function allows updating the Enabled State register for couple of Elements. It allows suspending/resuming each Element.
NOTES:
  • Having an Element disabled doesn’t change how the Element is process, it takes same amount of time to go through Scheduler code for that Element.
Update Elements Value
This function allows updating the Value for couple of Elements while Generation is active. As parameters, for each Channel, it takes the Channel Index and, for each Element, the Element Reference and updated Value. If Value hasn’t changed since last call, it’s not written to FPGA.
NOTES:
  • - Functions used to update Elements are certainly called, under the hood, by “Load Scheduler Settings” function. It’s transparent to user.
  • Cf. Errors Table for actual Error codes used.
    1. While loading Scheduler settings, if number of Channels defined is higher than Number of Channels supported by Scheduler. Limit value (8 by default) will be stored in a Global.
    2. While loading Scheduler settings, if number of Elements defined is higher than Number of Elements supported by Scheduler. Limit value (256 by default) will be stored in a Global.
    3. While loading Scheduler settings, for the list of Channels Settings passed, we check that each Channel Index is unique (not duplicate), otherwise, we return an error.
    4. While loading Scheduler settings, for the list of Channels Settings passed, for each Channel, we check that each Element Reference is unique (not duplicate), otherwise, we return an error.
    5. While loading Scheduler settings, for the list of Channels Settings passed, if array is empty, we return an error.
    6. While updating Elements values, at least one Element doesn’t have a known Reference.
    7. Given Elements defined for a given Channel, we don’t check whether it represents a bus-load which is reachable. It could be added, it would require knowing the typical duration per Element. It could be added in the future as a check. We could add a function that gives, per Channel, the bus-load (%).
Error Checking
Errors caught
Errors not caught
  1. Given Elements defined for a given Channel, we don’t check whether it represents a bus-load which is reachable. It could be added, it would require knowing the typical duration per Element. It could be added in the future as a check. We could add a function that gives, per Channel, the bus-load (%).
Errors Table
Error Code
Error Message
5000
Scheduler Settings: number of Channels Configured is higher than what is supported by Scheduler.
5001
Scheduler Settings: number of Elements Configured is higher than what is supported by Scheduler.
5002
Scheduler Settings: at least one Channel Index is not unique in the list of Channels Settings.
5003
Scheduler Settings: at least one Element Reference is not unique in the list of Channels Settings.
5004
Scheduler Settings: Channels Settings array is empty.
5005
Scheduler – Update Value: at least one Element doesn’t have a known Reference.
Host Examples
The Scheduler comes with 2 examples. These examples are available in library “HW_Scheduler_Host.lvlib”, virtual sub-folder called “Examples”, under RT PXI Target in joined LabVIEW Project.
Example 1
This example called “Host_Main_Test_002.vi” is a typical usage of the Scheduler. It’s a loop-back test between FPGA Scheduler and a separate FPGA loop which timestamps Element generated and sends them back to Host. Example only requires a NI FPGA based target and 2 DMAs (one for the Scheduler, second one to retrieve data) to run. Inside Host part, there are 09 test-cases which illustrate different use-cases.
Inside the example, there are also small features to take statistics on Element generated and display in a XY-Graph, per Channel, the received Elements value.
Below is a screen capture of the Example Front-Panel:
  1. FPGA Resource Name.
  2. Number of Elements sent. It’s a DEBUG indicator from FPGA. It’s for all Elements from all Channels.
  3. There are 09 different Scheduler settings that can be used for testing.
  4. Button to STOP Application
  5. Array of Elements statistics (one element per Scheduler Element) which shows statistics computed on the last DMA buffer read. It gives:
    1. Mean Period (ns)
    2. Standard Deviation (ns) of Period
    3. Maximum Period (ns)
    4. Minimum Period (ns)
    5. XY Graph which shows the Element Values received. By default, 07 Elements are displayed. It can be changed in code.
    6. OPTIONAL. Control to update Element Values, “on-the-fly”, while generation is running.
The capture, below, shows diagram of the same example. Cf. Notes for function details.
Example 2
This example called “Host_Main_Test_003.vi” is an example which can be used to benchmark how long it takes to update all Elements value, while running for a given target.
It’s just for indication but I put execution performances for RT Loop in the Example diagram. They are not commitment but indications based on a test run on 2 targets.
Communication with FPGA part: Architecture Overview
Typically, this implementation has a memory space used to store Elements (actual data) to generate. For Arinc-429, it would be the Labels value. It is a unique spaced shared between all physical channels from Scheduler, allowing having a variable number of elements used per Physical Channel.
At FPGA level, the Scheduler manages a series of Physical Channels.
One of the challenges is to ensure that generation timing doesn’t drift over time. Here, the Scheduler uses an external absolute timing Time Source which makes Time in ns (nanoseconds) available for other functions from FPGA. For the moment, I simply simulate that absolute Timing Source but we could use the FPGA Time-Keeper driven by an external GPS, IRIG-B…
The Host sends a set of low-level “Commands” to be executed on the FPGA. The Commands content is described later in the document.
Low-Level COMMANDS (from Host to FPGA)
These commands are not those accessible via User API directly.
Commands Skeleton
Each Command is a U64 Data.
63-----------------------------------------------------------------------------------------------------------------------------------4    3------0
DATACMD
CMD
  • 0-3: CMD, 4 bits, 0-15d. Command type.
    • 4-63: DATA, 50 bits. Data.
Commands List
CMD
Name
Description
0
Load Data to EVT
EVT: Elements Value Table
1
Load Data to CDT
CDT: Channels Descriptor Table
2
Load Data to EET
EET: Elements Enable Table
3
Load Data to EC
EC: Elements Configuration
4-12
For future use
13
Get Current Status
To Be Completed
14
Start Generation
Start Generation on all Channels.
15
Stop Generation
Stop Generation on all Channels at the end of current Command.
NOTES:
  • The Commands can be sent either before generation beginning or during generation.
Commands Arguments
CMD
Arguments (54 Bits)
0
4-15: Not Used
16-31: Element Index
32-63: Element Value
1
4-15: Not Used
16-31: Start Index
32-63: Number of Elements
2
4-15: Not Used
32: Enable Value
33-63: Unused
3
4-15: Not Used
FPGA Code Architecture
The FPGA part receives data/commands from the Host part using a DMA. The actual scheduler part of the code relies on an external Time source (in ns). In examples, this Time source is simulated.
Host <-> FPGA Communication
  • DMA Host -> Target
    • - Element Type: U64
    • - Size: Default
    • Controls/Indicators:
      • - Controls
        • Number of Channels. It defines actual number of Channels used.
    • - Indicators
      • None
FPGA Memory Blocks
Summary
Memory Blocks
Number of Elements
Data-type
Details
Elements  Value Table (EVT)
256
U32
Actual Value sent to Channel when Period expires.
Channels Descriptor Table (CDT)
8
U32
U16 (Start Index) + U16 (NB Elements)
Elements Enable Table (EET)
256
BOOL
If TRUE, this Element is Enabled.
Elements Configuration (EC)
256
U32
U32 (Period in ns)
Elements State (ES)
256
U64
U64 (Last Tx Time, in ns)
This space defines, per Channel, memory spaces arrangements. Per Channel, it’s a U32 data which combines 2 pieces of information:
  1. U16 (Start Index). They are the 2 lowest bytes.
  2. U16 (NB Elements). They are the 2 highest bytes.
Using that information, it’s possible to determine, per Channel, what is the memory area involved for memory blocks: EVT, EET, EC and ES.
It’s the shared Memory Space between physical Channels for the storage of all Elements (Labels for Arinc-429) values. Here, we defined it with 256 elements. For each Channel, CDT information gives the address range involved.
Each Element Value is a U32 data.
Example: if you want to get/set Elements Value for Channel 2, you read the CDT(2). If you get 0x0003000A returned, it means that, for Channel 2, EVT memory space starts at address 0x000A and there are 3 Elements configured.
It’s the shared Memory Space between physical Channels for the storage of all Elements (Labels for Arinc-429) Enabled State. Here, we would define it with 256 elements. For each Channel, CDT information gives the address range involved.
Each Element Enabled State is a Boolean. If set to TRUE then Element is active, if set to FALSE, Element is inactive and not generated.
Example: if you want to get/set Elements Enabled State for Channel 2, you read the CDT(2). If you get 0x0003000A returned, it means that, for Channel 2, EET memory space starts at address 0x000A and there are 3 Elements configured.
It’s the shared Memory Space between physical Channels for storage of all Elements (Labels for Arinc-429) Configuration. Here, we would define it with 256 elements. For each Channel, use CDT information what is the address range involved. Each Element Configuration is a U32 data.
It’s the Element Period value in nanoseconds (ns).
Example: if you want to get/set Elements Configuration for Channel 2, you read the CDT(2). If you get 0x0003000A returned, it means that, for Channel 2, EC memory space starts at address 0x000A and there are 3 Elements available.
Elements State (ES)
It’s the shared Memory Space between physical Channels for storage of all Elements (Labels for Arinc-429) State. Here, we would define it with 256 elements. For each Channel, use CDT information what is the address range involved.
Each Element State is a U64 data. It’s the Absolute Time in nanoseconds (ns) when Element was last generated. If Element has never been generated yet and/or Generation is suspended, value 0xFFFFFFFFFFFFFFFF is used.
Example: if you want to get/set Elements Configuration for Channel 2, you read the CDT(2). If you get 0x0003000A returned, it means that, for Channel 2, ES memory space starts at address 0x000A and there are 3 Elements available.
Output
Data generated by Scheduler is placed in a Local FIFO with a way to distinguish the Channels. It could be changed later to have a local FIFO per Physical Channel.
Testing
  • The heart of the Scheduler has been tested first using Desktop Execution Node with couple of use-cases. It allows validating a good portion of the code without compiling it AND it’s also useful if there are also newer versions.
  • The Software comes with 2 examples showing how to use-it. As the Scheduler is supposed to be as “bus-agnostic” as possible, the examples don’t rely on something else than a NI FPGA based target having DMAs available.
All Channels are processed sequentially. Below is an Excel spreadsheet export which gives the timing performances for different quantities of Channels and Elements (we assume it’s for Arinc-429, so Elements here are called Labels).
NOTES:
  • To compute performances, we assume the following:
    • Scheduler FPGA Heart runs in a Single-Cycle Timed Loop (SCTL)
    • Scheduler’s SCTL relies on a 80 MHz clock (one Tick last 12.5 ns)
    • Per Label, processing takes 2 Ticks and you have to add one Tick per Channel used.
    • If a Channel is in the Channel list BUT has no Element configured inside, the Scheduler supports that. It’s something that could happen frequently when Scheduler is used in a Generic application where, during programming phase, we don’t know which Channels will actually be used.
    • The “Period” column is the minimum we could reach (taking into account that a Label lasts 320 us + 4 Bits time of GAP). The GAP is a minimum silence time between 2 consecutive Labels on a given Channel (it's generally 4 bits). We assume we are working in HS Mode (100 kbits/s). Each Label consist of 32 bits.
Processing Time (Ticks)2 Ticks per Label + 1 per Channel
Tick Duration (ns)12.5
Bit-Rate (Bit/s)100000
Bits Per Label32
Gap (Bit)4
    • The “Frequency” column is the reciprocal of the “Period” column.
    • The “Jitter (%)” column is the ratio between “Jitter (ns)” and “Period (ms)”.
    • The cases describe some sort of worst cases which are not necessarily real user-cases.
NB ChannelsNB Labels Per ChannelJitter (ns)Period (ms)Frequency (Hz)Jitter (%)
1137.50.362777.780.010%
21750.362777.780.021%
31112.50.362777.780.031%
411500.362777.780.042%
813000.362777.780.083%
1262.50.721388.890.009%
14112.51.44694.440.008%
221250.721388.890.017%
32187.50.721388.890.026%
18212.52.88347.220.007%
242251.44694.440.016%
422500.721388.890.035%
34337.51.44694.440.023%
116412.55.76173.610.007%
284252.88347.220.015%
444501.44694.440.031%
825000.721388.890.069%
38637.52.88347.220.022%
466502.16462.960.030%
464645023.0443.400.028%
132812.511.5286.810.007%
2168255.76173.610.014%
488502.88347.220.030%
849001.44694.440.063%
3161237.55.76173.610.021%
232162511.5286.810.014%
41616505.76173.610.029%
8817002.88347.220.059%
3322437.511.5286.810.021%
432325011.5286.810.028%
81633005.76173.610.057%
832650011.5286.810.056%
  • The takeaway is that if we have the Scheduler implemented with these performances, it satisfies a certain number of applications because FPGA space required is minimized and with still decent performances (jitter never exceeds 0.083%).
Known Limitations
  • There is no feedback about Scheduler state. If something goes wrong in FPGA part, we are not really aware of that situation. A Status information could be elaborated with, for instance, an Element counter per Channel. This counter would be coded on a U32 for instance and would rollover to 0 once it reaches its maximum. User would use Command 13 (Get Current Status) to retrieve value. Where it wouldn’t give information, per Element, it would at least let user know whether or not there is an active Generation on the Channel. This feature could be added and Enabled/Disabled via a Conditional Symbol to let developer choose to use it or not to save FPGA space.
Contributors
