Overview
This is a very simple VI that compares an array with a value and outputs an array based on the desired operation.
Description
This VI allows the user search and find the values of an array that comply with the search parameters specified by the user. Using the enum control Operator with the possible values of "Greater Than", "Less Than", "Equal To" or "Not Equal To"; and using as comparing reference the value of the Compare Value control.
Requirements
LabVIEW Base Development System.
1. Fill the Array In with the array you would like to analyze
2. Set the value you would like to compare to
3. Select the operation to perform
4. Run the VI
