Example Code
Simple Analog Window
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To demonstrate how to set up simple analog window with In-Range indicator
Description:
This example shows how to set up a simple analog window.  It takes in an analog signal and compares it to a user-defined window.  It then tells the user when the value is in range and coerces out of range values to the nearest limit.  This can then be used in any application where the user wishes to control other operations based on the value of an incoming analog signal.
Instructions:
To implement this example:
  1. Set the upper and lower limit.
  2. Run the VI.
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Chris L
Certified LabVIEW Associate Developer
