Example Code
Show TCP/IP Device on Network Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will list all the TCP/IP devices connected to a user specified target.
Description
You can use this VI to show the target on the net by TCP/IP. The VI get the information from localhost target. Filter the device connected to system by TCP/IP and find de hardware and write the basic information of the device to an array. Close the reference to a previous source, simple error handle and display the result.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the target
  • Run the VI
VI Snippet
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
