Overview
This VI demonstrates the use of the mouse move event within the plot area of the intensity graph.
Description
You can show the X,Y, and Z values of an intensity graph next to the mouse as it is in the plot area using this example code. The VI makes use of the Mouse Move event within the Plot Area of the Intensity Graph. Then, it correlates the location of the mouse in the plot area to the array of the graph and then writes the values to a cluster indicator that moves with the mouse.
Requirements
Software:
I did not use tool strips because the appear slowly and then do not move with the mouse.
how can i make the same for graph indicator of mulitple plots
Thanks great example.
