Example Code
Setting Begin and End Values for X-Scale in DIAdem 2D axis Using VB Script
Products and Environment
    Software
  • Diadem
Code and Documents
Description
Find attached a general script that allows you to set begin and end values for the X-axis of a 2-D Axis in the REPORT panel of DIAdem.
You need to determine what the begin (XMin) and end (XMax) values are going to be.
How to Use
  1. Download the attached script: Set XMin and XMax.VBS
  2. Open DIAdem.
  3. Add a 2D axis in the REPORT panel.
  4. Load the script in the SCRIPT panel.
  5. Choose values for XMin and XMax.
  6. Run the script.
  7. Notice how the X-axis limit values are now set to XMin and XMax in the REPORT panel.
Related Links
Control report x axis length with script
