Overview
This example demonstrates how to set the visible index of an array using a property node.
Description
The Visible Index slider control is connected to a property node for each array (X, Y, and Z). The property nodes correspond to the Index Values property of each array. This property node can be created by right-clicking on the array in question and navigating to: Create » Property Node » Index Values. This functionality is encased inside of an event structure that fires every time the Visible Index control's value changes.
Notice that the timeout is wired to -1 after the first iteration; therefore, the event structure will wait until the value changes before progressing through the code. Finally, there is a While Loop to allow the event structure to fire multiple times.
Requirements
Software
Hardware
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Dan King
Could you please add a sceenshot of your Block Diagram
