Overview
This example shows how to set Windows system time using LabVIEW and the kernal32.dll.
Description
This code set the Windows system time using LabVIEW and the kernal32.dll. Make sure to right click on LabVIEW and Run as Administrator before using the program.
Requirements
Front Panel
VI Snippet
i have tried this vi in different PC's and different OS. But it is not working. let me know i missed anything.
The setsystemtime.vi and Set System Time 2012 NIVerified.vi sets the time in UTC format. It might look like the setting is not working properly if you try this VI from different time-zones. There is another function from MSDN Kernel for SetLocalTime. I have attached a VI Set System Date Time (UTC & Local Time).vi which does both UTC and Local Time setting.
PS: VI is in LV2014 version.
