Example Code
Set Symbols In ListBox Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a quick way to create symbol for the list box.
Description
You can use the property node of the lisbox to create 40 kinds of multicolumn. You can also select the item names of the symbols.
Requirements
  • LabVIEW 2012 (or compatible)
  • Run the program
VI Snippet
Comments
Not applicable
on
Ok,
This is great. Unfortunatly there is no documentation. Normaly you can set Icons only in the first column. In combination with custom symbols, http://zone.ni.com/devzone/cda/epd/p/id/6175  and http://lavag.org/files/file/31-type-sensitive-popup/ there are much possibilyties for MCLs.
Is this control designed by you? How have you done this? When I use it, can I be sure that it will run under the next LabVIEW Versions? Is it also possible to change the alignment (center instead of left) of the symbols?
Sletrab
Not applicable
on
Maybe someone else can explain me how this can be done?
The column and row header cell from this example MCL do not have the right background color for a system Control (the same white like the normal cells). And it can not be changed.
Any suggestions?
Sletrab
don.lee
Member
Member
on
Hi raw,
This is great.Could you explain me how this can be done? Thank you!
GregFreeman
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
http://lavag.org/topic/7002-multiple-glyphs-columns/page__st__20
See that thread to see where this came from and is discussed.
Not applicable
on
At http://lavag.org/topic/7002-multiple-glyphs-columns/page-2 is an Version of this Control, where you can set the Color of the Row and Column Headers. I added it as MCL SystemStyle with Items for every Column Version 2.ctl
in LavVIEW 12.
arul94
Member
Member
on
Why can't I find this control in the default palette? Is it still under development?
