Example Code
Set Front Panel Contents to Top Left Location in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates moving the contents of the Front Panel to the top left area of the front panel.
This example is useful because moves all items on Front Panel to the Top Left in the Pane. Use all controls/indicators in the Front Panel and then move the scroll bar to an upper position. Running the VI moves all items to the Top Left in the Pane.
Description
Use VI property nodes to identify the VI and the panel, then set the position for the window (panel) and scroll bars (pane).
Requirements
LabVIEW 2012 (or compatible)
  1. Move scroll bar to a upper position
  2. Run the VI
Mike S
NI AE
