Example Code
Set Control Values by Index (Signalling) in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows you how to use the Set Control Values by Index function.
Description
Depending on the order that controls are placed on the front panel, you can modify its values based on the Set Control Values by Index function. Additionally, this function also allows the change to be picked up by an event structure.
Requirements
  • LabVIEW 2013 (or compatible).
  1. In the block diagram, put in the corresponding control values in the constants as required.
  2. Run the program.
  3. Notice that the values in the controls have been modified accordingly.
Block Diagram
__________________________
Aidan H
National Instruments UK & Ireland
Comments
sfanale
Member
Member
on
Just to note, this code uses the tabbing order of the controls, not the control index, to send the value chnage signal. I'd reccommend adding an input for an array of control references that you want to modify. these references can be used to grad the control indexes too.
