Overview
This code allows the user to easily set the channel name of appended signals to a Write to Measurement File Express VI.
This example is useful because adds a channel name to a .lvm created using Write to Measurement File Express VI. This VI also merge two groups of signals, in this example are created from Simulated Signal VI Express and For Loop that simulates GPIB adquisition.
Description
Use For Loop and Simulate Signal to create a couple of signals. Using Set Waveform Attribute Function add the hard code header then merge the signals and use Write To Measurement File VI Express to Write the signals into the specified file.
Requirements
LabVIEW 2012 (or compatible)
1. Open the VI and switch to the block diagram.
2. Configure the Write to Measurement File to write the data to a known location
3. Run the VI
