Overview
This example is developed to test the serial port in simple way.
it has a very good UI.
Description
I have developed Utility which worked like Windows hyper terminal utility.
HyperTerminal is a program that you can use to connect to other computers, devices and host computers.
HyperTerminal has capabilities beyond making connections to other computers and devices. It can, for example, transfer large files from a computer onto your portable computer using a serial port rather than requiring you to set up your portable computer on a network. It can help debug source code from a remote terminal. It can also communicate with many older, character-based computers.
HyperTerminal records the messages passed to and from the computer on the other end of your connection. It can therefore serve as a valuable troubleshooting tool when setting up and using your serial port. To make sure that your device is connected properly or to view your device settings, you can send commands through HyperTerminal and check the results. HyperTerminal also has scroll functionality that enables you to view received text that has scrolled off the screen.
Requirements
Software:
VI Snippet
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Do you have this VI for LV 8.5?
Having problems with Windows 7 and RS232 communication.
Hello Sir.
i am doing simillar one,i need to communicate with my microcontroller through serial port,but i didn't get how to read the data from predicted loaction,i interface a eeprom with Microcontroller i did the eeprom interfacing with microcontroller,even i tested in hyperterminal it will working fine,Ex-when i want to read i will give RP 0x0020 then i can read the data of eeprom similar write also,same thing i want in labview without manual interaction the labview will read and write,i did by using VISA read and write i am getting error.even when i going to check your example Vi simillar thing happen,please help me how to do.
Raikar A G
This VI is VERY close to what I need! I am trying to read a Mettler Toledo balance. I can use this code as written and see the read characters just like I want! Now my problem is my lack of LabView skills to take the essentials of this interface and make it useful for my specific needs. I need the read data to be saved to a text file. I would prefer an independent VI that does not have so many generic selections. I don't need the hard close of the window and all else. My basic project is to read thermocouples via a DAQ and this scale in a single interface writing all data to a file. I have this working easy enough for the thermocouples but I don't know how to make it happen for the scale readings.
Any help is appreciated.
Doug White
Hi NI Guys,
I am very new to NI LabVIEW, now only am learning basic things. Now I like to learn serial communication.
My scope is, Ill transmit ASCII data in terminal, LabVIEW should read and parse the data to indicators.
For eg. in serial port ill send temperature rated data should display in meter gauge.
