Example Code
Send Files to Recycle Bin or Delete permanently Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a quick way to use the invoke node of File System to delete file.
Description
This example shows how to use the FileSystem.DeleteFile Method (from the Microsoft.VisualBasic.FileIO class) to send files to the Recycle Bin. You can also Delete Files permanently if you need to.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the file path and options to delete.
  • Run the program
VI Snippet
