Example Code
Select Folder with Folder Dialog Browser .NET Object Using LabVIEW
Products and Environment
    Software
  • LabVIEW
  • Other
Code and Documents
Overview
This example shows how to create .NET instance like Folder Browser Dialog.
Description
When prompting the user for a path, it is sometimes desirable to not be able to select a file and only a directory. While the user could press the "Current Folder" button to return the path of the directory they are currently browsing, Windows provides a more streamlined dialog form to only select a directory.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run VI.
2. Select Folder path from .NET Dialog and see the result as "Path" and "Button Pressed" indicators on frontpanel.
Additional Information or Resources
NOTE: The VI's Preferred Execution System needs to be set to "user interface". This can be set under File » VI Properties.  If you do not run the VI in the user interface thread you will not be able to see your folder list.
PBear
NI RF
Comments
TroyK
Active Participant
Active Participant
on
Nice, although when I made mine I added a few more inputs.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
