Example Code
Select Controls by Label Text and Change Value and Enable Status Programmatically Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to programmatically select controls by label text, set enable state and change its value.
Description
This VI allows the user to select any number of Controls/Indicators from his Front Panel using the Control Names Array and set the desired Enable state for them, additionally if the control is a Numeric, Boolean or String he can select the value to be set before the Enable state change.
Note: The Control Name syntax should be Cluster Name/Control Name if the control is inside a Cluster and should be Tab Control Name/Page Name/Control Name if the control is inside a Tab Control.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Input the right name of the Control you want to enable or disable according to syntax note.
  2. Choose Enable or Disable or Disable and Grayed out in the front panel.
  3. Run the VI.
VI Snippets
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
