Overview
This example shows you how to create a web service that requires a login with user data logging that can be used in a browser.
Description
The attached examples are a web service project for LabVIEW 2013, 2013 SP1, and 2014. It is the resulting code from following the tutorial listed in the Steps to Implement section. There is only one extra VI called Get Auth Details.vi. This allows the username to appear in the XML code once logged in. This example's intent is to help get you started with using security. Make sure to play around with different configurations.
Reminders
http://255.255.255.255:8080/SecureWebService/Add/1/2
Requirements
Software:
LabVIEW 2013(or compatible)
VI Block Diagram
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Greetings,
Can you please explain why we have to uncheck API key. Will both NI AUTH and API key can be combined for web-service API.
Thanks.
