Overview
This VI exemplifies how to manipulate a .wav file and cut it.
Description
This VI uses the Sound Files VIs to open an existing .wav file and cut it to the desired time specified by the user and generate a new file. This could be useful to separate the data into sections depending on the user needs. It also calculates how many iterations of the new trimmed section of the audio file are necessary to cover the original duration time.
Requirements
LabVIEW Base Development System.
DirectX 8.0 or higher.
1. Open the attached VI "Trimmed WAV file LV 2012 - NI Verified.vi".
2. Run the VI.
3. Open the destination path.
4. Play the file named trimmed.wav
