Example Code
Search through data to determine when data exceeds threshold
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will search through a known set of data, and determine when the data exceeds a certain value.
Description
 When the data exceeds that value, another array is created, and the corresponding indexes of "data to be copied" will populate that array. When the data does not meet that threshold, the new array instead contains 0s.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Specify the data to copy;
  2. Specify the column of data to search and the element threshold;
  3. Run the VI and check the copied data.
VI Block Diagram
Comments
bsvare
Member
Member
on
You have rube in this code:
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Chantastic!
NI Employee (retired)
on
I appreciate the comment, but I have to say I have no idea what a rube is. Would love an explanation if you have time
bsvare
Member
Member
on
A rube is short for Rube Goldberg code.  Rube Goldberg is famous for creating machines that are overly complicated to do simple things. It's used by this community to attribute complex code to do something that can be significantly simplier. There's a great thread to read examples of these and how they can be simplier here: http://forums.ni.com/t5/BreakPoint/Rube-Goldberg-Code/td-p/399999
Chantastic!
on
Great, thanks for the information! Appreciate it.
