1. Overview
Example VI that allows the user to make a file search in a certain folder, get a list of the files present in the folder and finally select to open one.
2. Description
This example code shows how to use event structures, subVI calls, and the browser library to show and open different files using LabVIEW. The project contains a main VI called “Search File”, which allows the user to select a folder to search for files, as well as a search criteria, in case there’s any.
It also includes an additional subVI called “Select File” which displays a given array of found files and waits for the user to click in one of them.
If there are no files to display, the program will display a message to the user.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
