Example Code
Search a Specific String and Return its Corresponding Associated Value in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
From a multi-line string, search for a location name and return the ID number.
Description
This example uses basic string manipulation to search a multi-line string, for a location. Once the location is found, the corresponding ID number is returned. Note that this example assumes the source string is of a specific format. This can be seen in the attached vi below.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Place the desired location string in the control, an example string has been included as default values
  2. Run the program
  3. Notice that the ID that corresponds to the location is now displayed
Matt H
National Instruments UK
