Example Code
Search Outlook Email and Retrieve an Email's Subject, Body, and Return Address
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI provides an interface that will search for emails within your Outlook inbox that contain user-specified key words in the email's body.
Description
This example VI provides an interface that will search for emails within your Outlook inbox that contain user-specified key words in the email's body. The VI will then return an array consisting of the resulting emails that meet the search criteria. The resulting array contains the subject, body, and sender email address for each email.
Requirements
  • LabVIEW 2012 (or compatible)
VI Block Diagram
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
Comments
Luong.Tran
Member
Member
on
Hi all
How to retrieve the attrachment file!
Do you have any example codo to download the attrachments file from outlook?
Best Regards
Luong.Tran
PJackson
Member
Member
on
Same question...  Does anyone know how to view/extract an attachment from an email received.
