Overview
This polymorphic VI allows you to search 2D arrays for a given element and will return an array of coordinates the element has been found at.
Description
This code include many Vis, it currently supports: Boolean, String, Double, I16, I32, U16, U32
But can easily be extended to support smaller numeric types (simply open another, change the representation of the array element and the single element and save as a new one, then open the polymorphic VI and add the new instance).
Requirements
VI Block Diagram
Hii
I have labview 2009 , can you please compile the VI and up it again ??
Done ![]()
There is a mistake on VI Block Diagram attached.
While Loop cycle would not stop.
Boolean signal for Conditional terminal should be taken before Not operator.
It is made correct in VI attached.
