Example Code
Scripted HSDIO Synchronized with NI-TClk
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
    Being able to generate data from multiple HSDIO devices using NI-TClk allows a programmer to effectively expand their channels.
Description
    Being able to generate data from multiple HSDIO devices using NI-TClk allows a programmer to effectively expand their channels. With NI-TClk you can generate synchronized data across several devices with very little jitter. Being able to add scripting into the program, allowing greater control over the behavior of your HSDIO device, would be extremely useful.
Requirements
    Software
        LabVIEW 2012 (or compatible)
        NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
    Hardware
        NI-HSDIO Devices
Instructions
    1. Select the devices in Resource Names.
    2. Run the VI
Dan King
