Overview
This application will scan a given directory for consecutive file names and will create the next file name in line. It assumes a certain naming scheme: File001.txt, File002.txt, File003.txt, etc
Description
This VI is meant to work with the above naming scheme only since it works by extracting characters 5-7 of the filename, but this can be modified in the code
Requirements
Software
LabVIEW 2012 (or compatible)
- Open the file Limit Remote Front Panel Connections - LV2012 NIVerified
Block Diagram
