Example Code
Saving Multiple Spreadsheets Programmatically
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to programmatically create spreadsheet files with different names every second.
Description
This code will create data inserted by the user and every second it will create a .xls file with the specified information, but with a unique name.
Requirements
LabVIEW 2015 SP1 (or compatible)
1. If desired, select the data to store in the files on the Block Diagram.
2. Specify a folder to store the files to be created.
3. Select the Run button.
4. Stop the execution with the Stop Button.
Kyle A.
Chief Applications Engineer
